H21 / H23 CE Release vx433F 7/25 | SatelliteGuys.US
  • Thread starter Thread starter dfergie
  • Start date Start date
  • Replies Replies 0
  • Views Views 845
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
Saturday, 7/25/2009, 11pm - 2:30am ET
H21-100, H21-200 and H23-600 vx433F
Areas of Improvements & Updates
TV Apps
Stability
Notes
· H21-100: High Risk
· H21-200: High Risk
· H23-600: High Risk
· H23-600 Only: Going back to National will go back to default settings and lose local market ID setting and may lose service authorization.
· H21 MRV feature has been temporarily disabled.
· Please report all non MRV issues.
Previous Notes
New Features
01 - Network
01 - Media Share
01 - Music Screen Saver
01 - Game Search
01 - 1080p/24
01 - OTA via the AM21
01 - Autotune
01 - Multi-Room Viewing
:::::::View Playlist from a networked HR2x or R22
:::::::Playback/Trick Play functions from any networked HR2x or R22
:::::::Press {LIST} to see HR2x or R22 servers one playback per server at a time
02 - Parental Controls when scheduling autotune
02 - MRV: bookmarks and resume playback from previous location
04 - Friendly name in network setup
04 - QuickTune
05 - Built-in Self Test
13 - Advance setup in remote control
Improved/Updated
02 - Support for more 1080p Sony TV models
02 - Faster Guide scrolling
02 - ATSC signal meter performance
02 - Fixed a screen saver issue
02 - ATSC setup screen now works on first boot
02 - Fixed reappearance of deleted autotunes
02 - UI updates ("tuner 2" and "tuner 3" references)
02 - Fixed Gray Screen or a PPV OSD appearing overnight
02 - Improved "Try Again" when trying to connect to the Internet.
03 - AV1/AV2 remote code refinements
03 - Improvements to DHCP network setup
04 - Issues with rebooting while in standby
04 - WGA600N Support
04 - Static IP Setup
05 - Stability
05 - Missing "Just a few seconds" OSD
05 - MRV playback and trickplay problems
05 - User Interface polishing
06 - Network services, Network setup, Network status
06 - One touch autotune via Enter key
06 - H21-100, SWM compatibility--will not affect other boxes
06 - H21-100, remote control support
06 - Removed "Reformatting Hard Drive" screen after Reset Everything
06 - Changing Display Language
07 - One touch autotune via Enter key
07 - WGA600N setup with WPA encryption
07 - Receiver not resetting
07 - Closed Captioning Loss
08 - Autotune on ATSC channels
08 - WGA600N setup with WPA encryption
08 - UI Improvements
08 - Missing spending limit unlock OSD
08 - SWM issue, Signal Strength H21-100
08 - System test H21-100
09 - Network Setup
09 - Autotune on ATSC channels
09 - Keyword search
09 - Screen flash coming out of Standby
10 - Improved Front Panel display on boot up
10 - IR Remote H21-100
10 - Remote setting when reset defaults
11 - PPV spending limit conversion (compared to national release)
11 - Video when switching to alternate audio
11 - Fixed blank reset everything screen
12 - Stability fixes
12 - Faster keyword search
12 - Reset everything warning message
13 - Autotuning when using parental controls
13 - Fixed "tune to 201" issue
13 - Reset defaults correctly sets the hide/show SD duplicates option
13 - Updated connection successful message in Network setup
13 - Stability
14 - Autotune Fixes:
::::::Manual with past start times
::::::Lingering icon after canceling
::::::Parental Controls
::::::Minor polishing
14 - Updated welcome screen and help messages
15 - Autotune Scheduling with Viewing Hours set
15 - Preserve favorites when converting from NDS to DIRECTV firmware
15 - HDCP content protection H23-600
15 - Minor polishing
16 - Additional improvements to items from previous CE
17 - Scheduling autotunes
17 - Resetting the set-top-box in standby
17 - Call ID inconsistency
18 - Scheduling autotunes
18 - Coming out of standby
19 - Showings in Info Screen
19 - PPV autotunes when converting to new Middleware
20 - Improved tuning stability
21 - Under the hood
22 - MRV
22 - Aspect ratio changing on certain channels
22 - Bookmarks updates
22 - DIRECTV Subtitling (in TV options)
22 - Stability
23 - Autotune to XM Channels
23 - Stability
24 - Parental control
24 - Autotunes
24 - Stability
Trying to decide if missed recordings are a CE issue.
DVD AB Markers
