H20 local HD signal strength Question | SatelliteGuys.US
loudo
33
I dont have an H20 yet but i have a question:
When I test my signal on a particular local channel in SD, it always (except for bad rain) comes in at 100% signal strength, i believe this is because the spots have stonger signals.
Is it the same on the H20 with the HD locals??
I have an H20-100 and my local spot beam only shows 49%. But I have "moved" and am outside the spot beam's "estimated" reach by a couple of counties.
Amazingly though, during very heavy downpours, I never lose my locals to rain fade, even when I do lose other channels.
Heh, that's true, but there is no map of estimated hd spot beams as far as I know, they are supposed to be different from the sd beams.
This is exactly why i ask!!
i am "moved" too and get my chicago locals fine here in the middle of wisconsin and was wondering if the HD locals would come in also!!!
Guess i have to pony up and get the H20...........does anyone know if you can return this receiver in the first however many days if you dont "like" it?
Directv signal/footprint
new member with questions on 72.5 bird
