H20 CE Release 8/21 v.4134 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Window of opportunity to download:
Friday, Aug 21, 2009 11:00PM - 2:30AM ET
Saturday, Aug 22, 2009 11:00PM - 2:30AM ET
PLEASE READ THIS FIRST! DirecTV Cutting Edge Program: Terms, FAQ, How-To, Hidden Features, and More
If you have any issues with this CE release, please post them in this thread. We'll try to help, and DirecTV will see / be aware of your issue :)
For the latest updates, check out the Satelliteguys CE Chat on Friday nights:
chat.satelliteguys.us
H20-100 and H20-600 v4134 (Customer Candidate)
Fixes
• Improved Stability
Previous Release Notes
New feature(s)
  • 01 - DASH in full screen displays last 6 digits of RID
  • 01 - New Guided Setup screens
  • 01 - New music channel background and DMX channel logo
Improved/Update
  • 01 - Improved Caller ID
  • 01 - UI Polishing
  • 01 - Interactive channel fixes
  • 01 - Stability
  • 02 - UI Polishing
  • 02 - Stability
  • 03 - UI Polishing
  • 03 - Video Stretching Corrections
  • 03 - Improved Stability
  • 04 - Improved Stability
  • 05 - Improved Stability
  • 06 - Improved Stability
  • 07 - Improved Stability
  • 08 - Improved Stability
  • 09 - Black/Missing Background in the Guide
  • 09 - Improved Stability
  • 10 - Improved Stability
  • 11 - Improved Stability
Finally an H20 release! Hopefully this makes my box run a bit smoother.
+1 I've been having problems with the yellow button working on a sports channel. I have to pull upt the guide or switch to a non-sports channel to use it.
What release are you on? I think I'm on the latest national release as of 7/31 unless it auto updated. I can't wait for the CE, hopefully it helps a lot of the stability problems I've had with National Release.
i don't think the update worked for me, im still at 4104
I've got friends with a SD TV and when you put numbers in , it goes to the HD version automatically
Ah, it never occurred to me that anyone would still have an sd television! ;)
Unfortunatly, even if you do a Custom List, and remove all the HD channels, if you use the buttons instead of the guide, it still goes to the HD channel.
The HR20's have this option, hopefully the H20's will soon, but I'm just hopin, the H20 doesn't get many updates.
The H20 seems to be the red headed step child of the H series!
Yes, it is the first of the mpeg 4 stuff I think, in the H series anyways.
It was the first in any series to support mpeg4. I like the ota tuner since we have some good subchannels here in CT, but it would be nice to have the Ethernet connection to do mrv. Oh well!
Methinks you might want to consider an H23 and an AM21
D11-800 CE Release 8/28
H21 / H23 CE Release 8/28 v.434C
