H20-100 Ce # 9:03 1/11/08 | SatelliteGuys.US
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE / Version
H20-100 {CE:09:03} - 0x4044
Software Download Window:
Friday January 11, 2008: 11pm - 2:30am ET Saturday January 12, 2008: 11pm - 2:30am ET
Probability: 90%
PLEASE READ THIS FIRST! CE DOWNLOAD DIRECTION/AGREEMENT
The Contents of the Release: (Differences based of Last National Release)
  • Items from CE:09:01
  • Items from CE:09:02
  • Items from CE:09:03
Improved
  • 01 - SWM stability improvements
  • 01 - Interactive stability improvements
  • 01 - Pay-Per View stability improvements
  • 02 - UI polishing
  • 02 - Sound effects behavior improvements
  • 02 - ATSC stability improvements
  • 02 - Audio output stability
  • 02 - Remote control behavior improvements
  • 02 - General stability improvements
  • 02 - Interactive to program guide behavior improvement
  • 03 -UI behavior improvements
  • 03 - A/V stability improvements
  • 03 - Improved Search behavior
Updated
  • 01 - Guide UI polishing
  • 01 - Minor Guided-Setup UI polishing
  • 01 - Minor close-captioning polishing
New feature(s)
  • 01 - White GUI
Why does the H20 not tell you that you are d/l ing NEW sopftware like the HR20's ?
It also does not show the software version being loaded.
Jimbo
Jimbo
Earl has said that D* told him that it would take too much effort to change the message since the people that would see it are only ones forcing a download.
Rad,
Do you have a h20-100 ?
I tried the d/l and it still has the same version when it comes back on, this is why I asked my previous question !
talk is saying it should be like 4438 or something like that
Jimbo
Rad,
I am trying to re do my h20-100 d/l.
It appears to be working this time and surprise , surprise, it DID come up saying that it was finding new software !!!!
Jimbo
I've gone through the process twice & even though it says that new software was found & it d/ls fine, the version is still the same--no update.
Actually, I think someone posted previously that the version is the same, but the d/l does take place.
jimbo
They are experiencing an issue with the H20-100 download.
Looks like it is corrected and the new version is in the stream as of midnight.
Rad,
Jimbo
Jimbo, no I have the H20-600. When I do the force download it always says new software found, even if it's reloading the same level, just doesn't say what the level is.
I had heard that the version doesn't change and D* knows this.
But you do get the new version, at least thats what I've heard.
I will have to try the d/l tonight and check it again.
Jimbo
CE schedules for Jan 11 and Jan 12
Hr20-100 & Hr20-700 Ce #11:01
