H to H for a BUD. | SatelliteGuys.US
H to H for a BUD.
kelleyga
320
I would like to buy a H to H mover for my 10 feet Dish.
Do they exist?
Are they expensive?
Where can I find them?
You are going to need a polar mount and dish actuator to make this happen with such a big dish.
Do they exist?
Are they expensive?
I believe that a BUD must be designed to have a H-to-H mount from the begining. They can't easily be retrofitted and the mounts aren't cheap to begin with.
With the regular mover that comes with my 10 feet dish how much can I move?
For example, if I get it set to start moving from PAS 3R from my left, Up to what can it move to my right????? :rolleyes:
The polar mount skews the dish too doesnt it? Isnt the elevation different for every bird? The dish I got has a frozen polarmount, and if I cant free it up, I will need to fix it. I got it from a house 10 miles east and slightly south of me, so the elevation should be very close if not right on, but to what bird I do not know. It mounts inside a 5' cast iron pipe bolted to a slab. I dont have the base yet, couldnt get the square nuts loose.
which offset angle?
DMX leaving G10R
