ground block enclosure?? | SatelliteGuys.US
glgeek
76
greetings,
the 4 lead ground block on the outside of my house needs an enclosure. something to clean up the looks and protect the connections.
looking for recommendations if you have any.
TIA
bruce
greetings,
TIA
bruce
When my neighbor had a new install, the installer took off the outside wall a 'TV Box' and installed a new 'TV Box'. It is about 3 1/2 by 6 or 7 inches. I asked the installer what he was going to do with the old box and he gave it to me.
I would check local hardware or HomeDepot to see if they have something like this. (or look for an installer and see if he has any throwaways)
It has a large and small hole at the bottom/short end and would be ideal. I haven't put mine to use yet. (lazy)
If you really want an enclosure, go down to Home Depot and buy a sprinkler controller enclosure.
What the heck is going on here?
My locals moved to 61.5
