Got my new QUAD....easy to install? | SatelliteGuys.US
sprinklerguy
110
Well, my friendly UPS driver just brought my new Legacy Quad....should be an easy install right?
Is there just a set screw that holds the twin on?
I will make a new run from an empty connection straight to my 811 and then have my 508 and 811 set up on same TV...
should be a no-brainer right?
Anyone?
There are two phillips head screws in the bottom of the bracket. Remove those, pull the LMB out change the coax connections over, put the lnb back on the bracket and and put the screws back in place. Piece of cake!
It was and I am up and running.....whew!
Now I won't miss anything on TV...record one, watch another. Plus I can watch HD all the time....excellent.
Thanks for the help
n00b question; What satellites am I accessing?
How to force complete update of EPG on 510
