Good signal strength yet fails setup on the Odd 99 & 103 ..... | SatelliteGuys.US
outerub
100
Michigan.
Helping out a buddy with his install. Pegged the 101 (all 95+). High 80's on both the 99 & 103 evens & odd's yet when I select "Continue" it fails the check for the odd 99's & 103's.
Slimline 3 with 4 outputs.
Any ideas ?
Your signal levels are not high enough. You should be averaging low 90's in the least. You pretty much have to get it nearly perfect.
Is this a new install or is this a movers or new receiver? If its an existing setup, he should call DirecTV and tell them to grant him a waiver if he's happy with his levels.
Yep you don't have it ditthered properly. You can peg 101 over a wide range compared to the 99 and 103. You lowest possible signal to pass is 86. Get it to that point or you will have signal issues with the HD.
Ordered Directv, would like to pre-wire what I can, help?
Signal Strength
