Getting started with FTA | SatelliteGuys.US
jwyrick
Hi,
Just recieved my Coolsat 8000HD reciever. I am trying to use my old 4DTV reciever with a ten foot mesh dish, horizon to horizon mount and C/Ku corotor. I have the unit hooked up and set to satellite L5, 97degrees. When I try to search for channels I keep getting a Nothing to update message an so far not able to recieve anything. I would appreciate any help or guidance. Jim:confused:
Hi jwyrick, welcome to the Forum. I don't know how you have it connected, but I have mine connected like this:
http://www.dmsiusa.com/add_a_receiver.htm
I don't have a Coolsat 8000, but I have a Coolsat 5000 and maybe they are simular in the menu's. Go into Menu, Installation, Dish Setting. Then set it up like this:
Satellite: IA5/G25 or whatever is in the menu, make sure it's the one for ku
LNB Power: ON
LNB Type: Single
LNB Freq.: 10750
22KHz: Off
Diseqc Switch: Off, or if you have a diseqc switch, set to 1.0 and set the Commited to whichever port the ku coax is connected to.
Also note that with BUD dishes, sometimes you may have to move the dish a click or few, one way or the other to get a signal on the ku side. Hope this helps. Good Luck!
Al
The 8000 has a different menu structure
setup would be
dish 1 (2,3,4 whatever you want the satellite to be)
satellite IA5 (T5)
transponder (make sure its an active one)
LNB power-13/18v
LNB type 10750 for KU side, 5150 for C-Band
22k off
switch type Diseqc (if you use one)
diseqc 1,2,3,4 (whatever port its on)
Anyone know about the NHE 2500 receiver?
LO Frequency for DirectTV lnb
