mine worked with my VoIP service, but "I" turned it off because I think its annoying.
Leafs99 said:I also think it's annoying but my wife doesn't. I'll try hooking up a phone line to my receiver and see what happens. Thanks guys.
I like it when it works. Seems once a week I have to reboot the receivers for the caller id to work.
Are you with a regular phone company or voip ?
I have done both and had some issues while with the phone company working, but none since I went to voip. that said, I don't believe it's a issue with the companies supplying it as the service works on all my phones, just didn't some times on the recvr.
I don't look at it as an issue worth bringing up with D* as I feel it's an added convenience, if it was a TV recving television, then I would bring it to thier attention.
My guess would be the same way you do it with everything else. Plug a phone line from your receiver/DVR into a wall jack and a phone line from the majicjack into another wall jack The MagicJack will power all of the outlets in the houseHow do you set up your DirecTV caller ID with magicJack?
Exactly! There was also a "fix" that you can do to make the magicJack callerid more reliable when used throughout the whole house like this that involves wiring in a resistor. It's pretty simple and you can find it on google pretty easily.My guess would be the same way you do it with everything else. Plug a phone line from your receiver/DVR into a wall jack and a phone line from the majicjack into another wall jack The MagicJack will power all of the outlets in the house
Has anyone got caller ID working with Vonage onto their set-top box? What do I need to do to enable it?
Limited time offer
