Get picture but no sound | SatelliteGuys.US
GordonR
70
New Hampshire
I checked the TV by playing through the DVD player and Roku. Sound comes through on both of those.
Any suggestions on what may be the problem.
Satellite box, wiring, TV?
Thanks!
It could be any of the above.
I'm assuming you have the DVD player going into a different input on the TV than sat. If so...
*Unplug the cables from the DVD player and plug them into the satellite rx. Select 'dvd' on the TV... do you get sound? If no, problem is with the rx. If yes...
*Unplug the DVD's cables from the back of the TV and plug them into the TV where you normally have satellite. Select 'satellite' on the TV... do you get sound? If no, problem is the input on the TV. If yes, problem is with the cables between sat rx & tv.
Sorry,
Yea, I probably should have given more specifics.
It is connected using coax cable from the box to the TV.
This is hooked up via TV2.
TV1 is also connected via coax and that TV is fine.
Update:
I plugged in another TV using coax cable.
This one too will show video but no sound.
Would the satellite box bethe issue or the wiring?
I would guess not the wiring, but I could be wrong.
I have a 722 with TV2 connected via coax and TV1 connected via HDMI.
I restarted the satellite box and the sound issue is now fixed.
Thanks for all your input and advice.
Dish Network must hate returning Customers
Dilemma
