GeoSatPro GSL1C/Ku LNBF Pro Help | SatelliteGuys.US
wildboys
328
I just got the GeoSatPro GSL1C/Ku LNBF Pro from satelliteav.It did not have any instructions on how to use the lnb.It has two coaxial inputs on the lnb.I guess one is Ku and the other one i C-band.Do you have to use a diseque switch with this lnb.Does anyone have this lnb if so how do you set it up?My setup
QPH-031
Coolsat 5000
GEOSATpro 1.2M Offset dish
GEOSATpro CK1 C/KU LNBF
GEOSATpro C-Band Adapter Clamp
GEOSATpro GS120 HH Motor
GEOSATpro GS55mm Post Adapter
Please see attached photo for connections and LNBF orientation. (Please note that the GEOSATpro C/KU LNBF features the KU Standard LNB LO freq. 10750.) Often analog C-Band receivers cannot use the Universal type (9750/10600).
You can use any type of switch that you wish: DiSEqC, 22K, 0/12V.
Wiring:
Coax from satellite receiver to Motor Input >>>>>>
Motor to Switch >>>>>>
Switch to LNBF Ports >>>>>
Pansat 2700A again
Need Help In Ten
