Geosatpro 200c Freezing when I turn on the Beeper | SatelliteGuys.US
mediageek
39
Northern California
While installing my dish and trying to point it, I came across a possible bug. (Maybe I'm doing something wrong)
I have some TPs scanned into the receiver on this particular satellite (G16) and when I go into the menu and try to change my LNB settings, etc I press the Blue button to turn on the beeper and the Receiver freezes, no beep, no response to anything.
Am I doing something wrong?
What software is in the receiver?
I had the same issue a couple months ago and there was a software upgrade that took care of that issue. It was more of random remote freezing and not the receiver
SatelliteGuys.US - View Single Post - GeoSatPro DSR200
New Version GEOSATpro DSR firmware 1.27 is now available for download via satellite Galaxy19 KU OTA-SSU update.
Perform Manual Update then Factory Default to fully implement the new firmware.
Fix: AC3 Audio Lock-up
Fix: Random Remote Control Lock-up
Fix: Random C-band TP Lock-up
Add: Blind Scan Scan Options: FTA / ALL
Default: Blind Scan Ending IF Frequency: 1450 (change to match Standard Type LNBF)
Default: Search Option changed from SAT (FTA) to 1TP (FTA) in Search Screen
Default: OTA-SSU satellite, transponder and pids reassignment (press Red button in OTA screen)
If you have older software I highly recommend upgrading it
lnbf
Free Primestar for anyone who wants it
