GeosatPro 200 wont log channels properly | SatelliteGuys.US
Mr Tony
3,378
14,852
Mankato, MN
Having an issue on the GeosatPro 200
When I scan 97W usually 2 transponders wont log the channel names...rather just "unnamed 1, unnamed2, etc"
The TP's are always 12152 and 11966
If I remove the channels and rescan the 11966 TP will come in then (shows the actual names) but 12152 I cannot get it to scan properly. I have rebooted, deleted/rescanned, updated software, even done master resets...still wont work right
Anybody else seen this issue?
12152 and 11966
RRSat and GlobeCast recently changed the tables on these two MUXes and the Service Names now require extra time to capture and log. We modified the scan routine to allow complete PMT logging prior to function timeout in order to capture the Service Names. The fix is in beta and should be released with the next firmware update. We are working on another feature and will release both updates within the month.
good to know there is a fix. Whats weird is the Coolsat 5000 and Manhattan log them just fine
We have adjusted the timeouts to optimize scan times. If you allow for longer analysis time, the scan takes longer.
There is a fine line between capturing the majority of channels / information and increasing the scan time for all scans even when more PMT information is not available. In a perfect world, the tables would all follow uniform DVB standards and we would not need to account for non DVB compliant information.
Winegard DS-3101 with which motor?
WS International Polar Mount Needed
