GeoSat C2 or DMX242 ? | SatelliteGuys.US
AJV
SatelliteGuys Guru
130
Cadillac, Michigan
Looking to get a dual output cband lnbf so I can tie into my two receivers. Would like to know if anyone here has had experience when these lnbfs to give me some input if one is better than the other and why, to help me decide. Thanks for any help.
Check our Hardware Review Department.
One or the other got reviewed and written up.
I think that thread also includes comparison info on both.
And as I recall, both are excellent.
Thanks to the both of you. I'll check out the review also. I was just wondering if there were and pros and cons of the two, that sometimes you don't here about. Thanks for the responses.
Many LNBs and other FTA products are "generic" and are re-branded for different importers. Im using a DMS-422 dual feed C band which works very well. Havent tried any other brand labeled C band LNBs.
I thought that the numbers were a little better on the DMX, that's why I bought one, but I would agree with brentb636 & think the differences would be so minute to the human eye you cant tell.
I have both...one on each of the C-Band dishes I have for aiming at various sats...no difference on pretty much everything I've seen signal wise
gbox or vbox for dish deal
Question on C-Band Dish Idea
