Genie MRV Issue (No client used) | SatelliteGuys.US
Former member 134676
1,167
24
Everyday when I try to play a show recorded on my Genie to my H24 I get no Audio/Video packets sent from the server.
I know a reboot fixes it, but is there a way to fix this issue without having to do the reboot?
Nope. I have the same issue. All new cabling and it does it when the Internet is connected and when it's not. Just an annoying glitch
Thank you. Maybe someday a software update could fix this.
Did the installer run new cable? Is it 6 or 59 wire?
I'll have look. They are the ones that Dish Network installed when I first moved here.
I'll have to see if I lose MRV to my HR24 as well or if its only the Genie.
The wires are 6. Yesterday I got it to work without a reboot being required. So I hope it start working that way more often.
So far after making this post my MRV has worked normal. So not sure what changed but I won't complain.
I lost signal
Genie Question
