Genie Client Problems | SatelliteGuys.US
jgags6
1,107
68
Rockford,IL
Hi Guys, I had the Genie system installed over a year ago (HR34, 3 clients) and about once a month once of my clients does not work... When I go to turn my bedroom client on it comes up with a black screen. I reset the client, it shows the blue "restarting" screen, then the screen goes black again. I have tried everything, and I thought maybe the Directv switch has a glitch in it so I switched the inputs and still this happens. The client will not work the rest of the night until the next day. I have even tried switching clients when this happens and the client I put there still does not work. Is this a wiring problem? I'm stumped. Thanks for the help
If you move a different client to that location and that does not work then it looks like you have a cabling problem of some sort.
Is that something that Direct will fix or should I call the local company that I used to wire my home and initially set up the Directv?
The genie streams data to the clients for them to operate and is very critical that all wall plates or 3 GHz and all the wire is RG six and all fittings the perfect or it will not work perfectly that means no crampon fittings they crush the wire and change the shape
Posted Via The SatelliteGuys Reader App!
DirecTV supplies all material to spec for insulation usually when I was a car employee of DirecTV comes to a job it's using up to spec with so I would call DirecTV for proper insulation Henderes a warranty for 90 days if there is an issue so no charge to you
Big Problem...Code 775
My CenturyLink on DIRECTV
