Generic sats on DSR-922 | SatelliteGuys.US
choelzen
7
wyoming
Has any one looked at the Generic sats built into the DSR922 on the new X4?
Here are a few examples:
on the X4 sat
Transponder 9
using CF at SR of 19.51
CF 261 is Planet Green
264 investigation Disc
others on T9...
Transponder 18
CF 440 Discovery HUB
441 Science chan
443 OWN
just a sample, I just started poking around.
Can we still go and get Nebraska and other 4DTV channels using CE ch170 to 174?. SR 29270 ?
Also if you didn't do the 7 step you can use CA to CF to get all the channels on the new X4 if you still have the old X4 maps.
So if you did do the 7 step conversion with the DSR922 you can still get sats and channels not mapped.
Chuck
P.S. it took a good part of 2 days to get switched over to the new stream, firmware problems in one receiver and hardware problems in the second. Now MOSTLY up and working with the 922. Thanks again to Skyvision people!
Any reason my quality level dropped after the w5 to x4 conversion?
6 foot dish and dvb-s dvb-s2 CBand
