Gemstar dish | SatelliteGuys.US
Gemstar dish
southtx
39
I need some feedback on this products-gemstar ISA76cm Dish with ISA-321 Standard KU band LNBF. I would appreciate any help.
Seen a few on Ebay, was afraid to try em cause I had never heard of em. If you do try one, let us know. Sometimes one of us will "take one for the team" and find out the good, bad, or ugly portions of these dishes. I tried a Sat Radar which is a knockoff of the GeoSat Pro and didn't have any problems. The mounting is way different but no change in signal quality compared to a Fortec. (testing on G10 that is)
G10 is always a priority to me. If I can't get my G10 channels, it's OTA for me, and you know what that means. ZZZzzzzz
Thanks techno935, I saw those on e-bay also, so I emailed several buyers for some feedback and they rated them as very good on both dish and lnb, but I though I would ask in this forum to see if any FTAer had used them. Only you responded. Thanks again.
Problem with cable?
signal only on 3 transponders
