Game finder | SatelliteGuys.US
Game finder
DJMooty
49
16
Florida
Really dislike the recent change to game finder. It used to only use a small vertical strip to display all the information I needed. Now it occupies the whole bottom of the screen with very large icons for each game. Can't find any user options to select desired layout.
Sent from my iPad using the SatelliteGuys app!
Already being discussed here: Game Finder
To expand on your point, though, I also do not like the new layout. With the old vertical layout, it was easy to page up and down through the list of games. I do not see an easy way to page right or left through the new listings, other than move the cursor one individual game at a time. You can press and hold the right or left arrow button, but then the listings scroll too fast, instead of moving only a page at a time.
Plus you can't just pick one sport to see what's on without unchecking all the sports except what you want. It used to that you could check one sport and see what's on. :mad:
Press the down arrow on the remote and you can see each sport one at a time.
Yes, that works, but it can be annoying, depending on how far down on the list your favorite sport is buried. I think that this would be more useful if there were a full-screen mode, and you could use the channel down (or channel up) button to move a page at a time, instead of having the banner only showing one shelf at a time.
Can I use traditional dish vs tailgater for outdoor service?
Marshall Broadcasting dispute
