Galaxy25, what is this Channel | SatelliteGuys.US
mr.crane
Blind Scanned channels on this bird, lots of channels, but only get the
Azetecas, which is what I wanted. Quality on about 65 channels is about
54. Like I said only video channels I get is Aztecas, there are a couple of
channels Audio only. What are these channels. VNS1, VNS2, ETC.
I know they are Porn channels, according to the EPG. Had a wild feed
was a Golf Tournament.
are you sure you're on 93W completelly?
Azteca is very strong and you could be getting 95W next door or possibly 91
When I scan 93W I get 14 channels
-Azteca (4 chanels)
-Wright Patterson (9 scrambled)
-Justice TV (scrambled)
-Azteca (4 chanels)
Yes, sure it is 93w , Aztecas are coming in very strong, I also see there
is Justice Tv, no video/audio Iceberg, I changed the GeosatPro Bullet, and installed the Invacom Quad, have Lnb setting on 3500 as Standard!
Also see Wright Patterson. Could the Nimiq on 91deg, maybe bleeding over, like I mentioned there was porno channels, but all scrambled.
Iceberg, you are correct, must be Nimig bleeding over, because
on my epg I see Vu channels, and VN is for Venus. Confused, since
Nimiq is Circular, I know my Invacom Quad had Circular/Linear. I do
not have Circular connected, but somehow it is Bleeds over. Will
move dish slightly away from Nimiq.
I didnt think about Nimiq1 :o
I know sometimes when I scan 91W with the sathawk I get a couple ExpressVu TP's logged at way low quality
Glad you got it working :)
If you are just looking for the Aztecas, try using one of the Dish or Direct 18 or 20 inchers. Yes, Azteca is stong enough to still come in with a strong quality and no hassle with the bleed over from the adjacent birds. Of course you have to use a linear lnb not the circular that come on the dishes.
I'm Hooked! So what do the numbers mean?
Fortec Mercury II Stops Scanning
