Galaxy 19 97W TP 11904 | SatelliteGuys.US
Same as qwert1515 has posted. The new channels are on the horizontal polarity. Nothing on Vertical on those precise frequencies you listed. I manually entered that transponder and rescanned to be sure and all that I could pull in are the 11898 V 22000 ones.
Thanks for checking. For some reason the S9 is reproducing the 11898 TPs on TP 11904 V. Must be strange RF mixing going on in the front end.
This morning I removed the Avenger PLL LNB 10600 and replaced it with the GeoSatpro SL1 PLL LNB 10750.
No change, I can still scan in the 11898 channels on 11904 V.
What is even stranger if I change TP 11898 from V to H and do a scan I get the 10 channels from TP 11904 H!
Maybe I'll try my old Viewsat Ultra and see what happens?
Signal strength
Has anyone received 12.5W Eutel 12 West A?
