Galaxy 123 18 With no EPG in my FTA Rec. | SatelliteGuys.US
You might want to try Titan TV or Zap2it for a web based guide.
I use Zap2it, with a lot of playing around with locations, zip codes and Google you can build up a guide that covers a lot of the stations.
Here are a few zip codes that I remembered to write down that might help you
KATV Zip 72203 Little Rock ABC affiliate
KBTZ zip 59731 FOX affiliate
KCBU zip 84043 ??? KCBUDT
KMMF zip 59804 similar to KATV
KUTF zip 59804 Spanish
KUSMDT zip 59716 PBS MONTANA
WGBXDT2 zip 02134 PBS World
WTTWdt3 zip 60625 PBS Create
KQUO zip 99201
WNGS zip 14202 ThisTV
The PBS stations are on AMC21
If you use a PC there are ways to directly import the data into an EPG
Just another reason I like a PVR.
Have a 500gb drive on my Visionsat IV-200.
So, once I find a show I like that's on daily or weekly, I program it in.
Then, whenever I want something to watch, several episodes are already recorded. - :up
Max distance from dish question
Are there any good IRC chatrooms for FTA?
