G25 dual LNB to 3 receivers | SatelliteGuys.US
godfather818
52
Hey guys, I have a dual lnb thats getting G25, I dont have a switch on the roof, so the two receivers are connected to the LNB directly. I want to add another receiver, what switch should I buy and where do I hook up the 2 lines from the dual LNB what part of the switch? thanks.
Get a 2x4 multi-switch or a 3x4 multi-switch. The 2 is a vertical and horizontal input from the LNBF, the 3 is a vertical and horizontal input from the LNBF with an OTA antenna input on the extra input, and the 4 are outputs to up to 4 receivers. Hope this helps..!!
STRANGE OCCURANCE
Building PC for DVB-S2 and HD - Recommendations
