G 19 software | SatelliteGuys.US
G 19 software
ANIMA
14
In that G 25 was moved over to 93, and G 19 moved into G 25's old place at 97 how do existing active receivers know to get programming from G 19 ?
You do not have to do anything if you got G25 before you will G19 instead of G25 if you dish is still point to where G25 was. You should still get all of the programing no problem.
You might want to change the name in your receiver from G25 to G19. The location 97W and all of the channels are exactly the same as when G25 was parked there.
Bob
Need help getting Fortec Star Mercury ll to switch satellites.
HELP!!! Losing either all G19 or all AMC4!
