FTA Setup | SatelliteGuys.US
FTA Setup
crypto221
17
I am going to setup a FTA in Florida. I have a few questions to ask. First how do you figure out the magetic declination i seen the chart and can't make heads and tails on how to do it. Second after i set up the dish ( i have a motorized dish) how do i find the satellites? are all the North American Satellites in the south west direction? Will the reciever tell me what i am pointed at. will it show the sat like 101 or 123? Sorry to ask all this but new at setting up a Satellite system.
Depending on the receiver you can setup more than 10 satellite positions, I have around 40 stored.
Code:
                    New Port Richey, FL 34655
          Latitude 28° 12.774'N Longitude 82° 40.842'W
                         Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Telstar 12   15.0W 101.0 105.6 11.0 -59.9
                     Intelsat 901   18.0W 102.6 107.2 13.7 -59.3
                     Intelsat 603   20.0W 103.7 108.4 15.5 -58.9
                            NSS 7   22.0W 104.9 109.5 17.3 -58.4
                     Intelsat 905   24.5W 106.3 111.0 19.5 -57.7
                     Intelsat 907   27.5W 108.2 112.8 22.2 -56.8
                   Hispasat 1C/1D   30.0W 109.8 114.5 24.4 -56.0
                     Intelsat 801   31.5W 110.8 115.5 25.7 -55.4
                     Intelsat 903   34.5W 112.9 117.6 28.3 -54.3
              AMC 12 & Telstar 11   37.5W 115.2 119.8 30.9 -52.9
                          NSS 806   40.5W 117.6 122.2 33.5 -51.4
                        PAS 6B/3R   43.0W 119.7 124.3 35.6 -50.0
                           PAS 1R   45.0W 121.5 126.1 37.3 -48.7
                     Intelsat 705   50.0W 126.4 131.0 41.4 -45.2
                     Intelsat 707   53.0W 129.7 134.3 43.7 -42.7
                     Intelsat 805   55.5W 132.6 137.3 45.5 -40.4
                            PAS 9   58.0W 135.8 140.4 47.3 -37.9
                         Amazonas   61.0W 139.9 144.6 49.3 -34.6
           EchoStar 3 & Rainbow 1   61.5W 140.7 145.3 49.6 -34.0
                 Estrela do Sul 1   63.0W 142.9 147.5 50.6 -32.1
                     Brasilsat B2   65.0W 146.0 150.6 51.7 -29.5
                     Brasilsat B1   70.0W 154.5 159.2 54.2 -22.3
                 Nahuel 1 & AMC 6   72.0W 158.3 162.9 55.0 -19.1
                        DirecTV 5   72.5W 159.2 163.8 55.2 -18.2
                            SBS 6   74.0W 162.1 166.7 55.7 -15.7
                            AMC 5   79.0W 172.3 176.9 56.8  -6.8
                          Nimiq 2   82.0W 178.6 183.2 57.1  -1.3
                            AMC 9   83.0W 180.7 185.3 57.1   0.6
                     Brasilsat B3   84.0W 182.8 187.4 57.0   2.5
                           AMC 16   85.0W 184.9 189.5 57.0   4.3
                            AMC 3   87.0W 189.1 193.7 56.7   8.0
              Intelsat Americas 8   89.0W 193.2 197.8 56.3  11.6
                 Galaxy 11/Nimiq1   91.0W 197.2 201.8 55.8  15.1
                     Brasilsat B4   92.0W 199.1 203.8 55.5  16.8
                        Telstar 6   93.0W 201.1 205.7 55.1  18.5
                        Galaxy 3C   95.0W 204.8 209.4 54.4  21.7
              Intelsat Americas 5   97.0W 208.4 213.0 53.5  24.8
                        Galaxy 4R   99.0W 211.8 216.4 52.5  27.6
                            AMC 4  101.0W 215.0 219.6 51.4  30.4
                            AMC 1  103.0W 218.1 222.7 50.2  32.9
                           AMC 15  105.0W 221.0 225.6 48.9  35.3
                          Anik F1  107.3W 224.1 228.7 47.4  37.8
         DirecTV 6 & EchoStar 6/8  110.0W 227.5 232.2 45.4  40.5
                          Anik F2  111.1W 228.9 233.5 44.6  41.6
                    Solidaridad 2  113.0W 231.0 235.7 43.2  43.3
                         SatMex 5  116.8W 235.1 239.7 40.2  46.3
          EchoStar 7 & DirecTV 7S  119.0W 237.3 241.9 38.4  47.8
  EchoStar 9/Intelsat Americas 13  121.0W 239.1 243.7 36.8  49.1
                       Galaxy 10R  123.0W 240.9 245.5 35.1  50.3
                        Galaxy 12  125.0W 242.6 247.2 33.4  51.5
             Galaxy 13/Horizons 1  127.0W 244.2 248.8 31.7  52.5
 Intelsat Americas 7 & EchoStar 5  129.0W 245.7 250.3 30.0  53.4
                           AMC 11  131.0W 247.2 251.8 28.2  54.3
                        Galaxy 1R  133.0W 248.6 253.2 26.5  55.1
                           AMC 10  135.0W 249.9 254.6 24.7  55.9
                            AMC 7  137.0W 251.2 255.9 22.9  56.6
                            AMC 8  139.0W 252.5 257.1 21.1  57.2
                     EchoStar 1/2  148.0W 257.7 262.4 13.1  59.4
        Satellite Finder is (c) Copyright 2004, P. Lutus
Also to keep you from getting in "trouble" both those sats as an example are encrypted dishnet sats and if you mistakenly ask about getting their programs via your new box you won't like what the mods will do to you. :)
Thanks for the info but should i ignore the skew since i am using a motorized system also what does Az (t) Az(m) mean? also E1. I am sorry but i'm to new to this
Yes set the LNB straight up and down on your zero position and the motor will take care of the skew.
AZ (True) = True Azimuth
AZ (Mag) = Magnetic Azimuth.
El = Elevation
I thought the moter only went side by side. Does it go up and down too?
The motor only goes east and west but because of the angles it raises and lowers the dish as it follows the arc, kind of tilts it to line up exactly with the satellite in the sky.
Where to buy standard Ku LNBF - D tube type
romanian channels
