Hutchie Member Original poster Feb 22, 2009 6 0 Barbados Feb 22, 2009 #1 Hi all, New to satelliteguys.us; great help so far. Is the Oscars showing on any free c-band satellites tonight? Or only on ABC on W3-500 or G3-582? Also, can anyone recommend a C-Band package reseller?
Comptech SatelliteGuys Pro Jun 26, 2006 3,678 2,844 Travelers Rest SC Feb 22, 2009 #2 Check out SLR's programming packages, I don't know if they will sell to you in Barbadoes or not. We don't discuss wild feeds here,but since you are so far away check your PM's. And by the way
equant SatelliteGuys Pro Apr 23, 2007 265 0 Tucson, AZ Feb 22, 2009 #3 ABC on 99W has them. Also check 95W NTSC.
Hutchie Member Original poster Feb 22, 2009 6 0 Barbados Feb 22, 2009 #4 Thanks, I should have mentioned I am using a 10ft BUD with a DSR-922. I found it on G3-23 with the help of some PMs.
