FSS LNB | SatelliteGuys.US
FSS LNB
whatchel1
9,098
51
Great High Plains
Is there somewhere that I can get an FSS LNB? I'm not looking for one with the built in feed horn on it. I have a feed from primestar dish that has a feed horn just like the FSS feed horn. I would like a low noise LNB that I can use to attach to the FSS feed so that it will be put it on 118.7 using my .9 meter (39 inch) dish and move to another LIL. I tried before with a 500 + but never could get enough SS to make it a solid signal. Since the .9 meter will have much higher gain pretty sure it will have the gain I need.
LineOfSight Question
Help with installation
