Frequencies for transponders for DP | SatelliteGuys.US
miguelaqui
1,002
28
Can someone please tell me where I can find the frequencies for the dp LNBFs so I can program my satellite meter? I specifically need t3, t7, t11. Thanks to all who can help!
Lyngsat.com is the place for tp and frequency
Sent from my SGH-I337M using SatelliteGuys
. If you are using a dp lnb, then the frequency will be different for the odd transponders .
It's been a while since I had to know since the new meters do it for you.
Left occupies 950-1450 with ascending tps and Right and occupies 1650-2150 with descending tps, if I remember correctly. So, tp 32 would start at 1650
verticals are normal
horizontals are 25600-the "legit" frequency...so 12238 would be 13362
edit: yup found an old post about it too
Formula for DBS Bandstacked LNB's is similar.
25600- (Horizontal Freq) = (BandStacked Freq as a Vertical)
Dish Sticks GetGlue to ‘Explorer’ App
picture-in-picture
