Fox Is Back? | SatelliteGuys.US
Fox Is Back?
Okay.
If you listen to the entire song (you may have to be totally stoned to do so), you'll hear her say that the grass always looks greener in the other yard. But, after you've been there a while and realize how good you had it back home, you can return and she'll welcome you back with open arms................uh, just like DISH.
Push the power button on your remote or on the Hopper 3 and Joey receivers. When the little green lite goes off your Hopper and/or Joey is in standby mode.
If you are using the 54 remote, and I'm sure you are, you will need to wait 5 minutes for the green light to go off. Then the units will be in standby.
Fox Might Take It!
DISH reaches long-term carriage agreement with Fox
