Fortec Ultra manual pid entry | SatelliteGuys.US
truckracer
4,338
352
Charleston wv
Hope this does not sound dumb, but i can't find where I can manually enter audio and video pids to create a channel in my Fortec Ultra. I try to scan the WB feeds on G-11, I have 99% quality on the transponder but cannot get the fortec to recognize the channels. I was told that the feeds are there you just have to manually enter them. Maybe some poor man's scrambling method that the fortec cannot map the channels into memory.
Can anyone help?:)
Under the main menu, check for "Advanced Scan." From there, you should be able to put in whatever -- frequency, SR, PIDS, name, etc...
102g install
Sadoun Sale: 10% Off for a limited time
