fortec star mercury not working | SatelliteGuys.US
all4jo
398
12
Haiti and lexington ky
hey guys , i purchased the fortec star mercury when it was linked thru this website for sale. anyways , i cant seem to get any chanels when i scan. first i tried scanning using my coolsat 3618 receiver and i get channels but when i switch it to the Mercury i dont get any. could the box be bad? or am i doing something wrong? im using a 8 ft cband antenna pointed at 45 pas1r.
thanks
Jose
Are you setting the info right for a c-band satellite?? Local osc-5150 for c-band I believe. Any switches involved that might have a bad port?
satellite-pas1R 45
symbol rate- full range
polarity-all
start frequency-3700
end frequency-4200
frequency step-4
mode - scan all
locking speed- detailed
Make sure you have the cable in the back plugged in to Digital LNB IN
Also, LNBF type should be 5150
Just one thing you might try? Hook up the Mercury thru the coolsat's loop out and then scan. I have an ultra that did the same thing. This way you know the lnb has power and the Mercury should find the same things as is being viewed on the coolsat at that time.
LNB frequencies for C band Vs Ku
MacGyver reruns FTA?
