Fortec Star Lifetime Ultra cannot update bin file | SatelliteGuys.US
boozekeg
Alberta, Canada
Hi Everyone!
I am a newbie to this FTA stuff. I recently purchased a Fortec Star Lifetime Ultra receiver and I have been scanning all the forums and FAQ's to learn more about this hobby.
I noticed that you can update the firmware on the Fortec unit using a program that is downloadable from the Fortec site as well as the appropriate BIN file (in my case NTSC).
I am not having any success and keep getting the "download failed" message.
I tested the cable and it is a "straight through" 9 pin female-to-female serial cable.
I ran a port monitor on my COMM1 PC port and logged the transmission to the device.
When the error message from the Fortec software appears (after what I assume is a 30 second timeout), I hit the cancel button (instead of the retry button) and then my Fortec unit will re-boot itself. The update is not applied an it says it has the same firmware that it came with.
Any help would be appreciated.
I have attached the log file from the data transmission below…
0 0.00000000 Fortecstar STB IRP_MJ_CREATE Serial0 Options: Open
0 0.00005908 SUCCESS
1 0.00000000 Fortecstar STB IOCTL_SERIAL_SET_TIMEOUTS Serial0 RI:-1 RM:0 RC:0 WM:0 WC:5000
1 0.00000166 SUCCESS
2 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_BAUD_RATE Serial0
2 0.00000103 SUCCESS
3 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_LINE_CONTROL Serial0
3 0.00000113 SUCCESS
4 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_CHARS Serial0
4 0.00000088 SUCCESS
5 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_HANDFLOW Serial0
5 0.00000103 SUCCESS
6 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_BAUD_RATE Serial0
6 0.00000091 SUCCESS
7 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_LINE_CONTROL Serial0
7 0.00000093 SUCCESS
8 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_CHARS Serial0
8 0.00000086 SUCCESS
9 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_HANDFLOW Serial0
9 0.00000086 SUCCESS
10 0.00000000 Fortecstar STB IOCTL_SERIAL_SET_BAUD_RATE Serial0 Rate: 115200
10 0.00001003 SUCCESS
11 0.00000000 Fortecstar STB IOCTL_SERIAL_SET_RTS Serial0
11 0.00000514 SUCCESS
12 0.00000000 Fortecstar STB IOCTL_SERIAL_SET_DTR Serial0
12 0.00000482 SUCCESS
13 0.00000000 Fortecstar STB IOCTL_SERIAL_SET_LINE_CONTROL Serial0 StopBits: 1 Parity: NONE WordLength: 8
13 0.00000318 SUCCESS
14 0.00000000 Fortecstar STB IOCTL_SERIAL_SET_CHAR Serial0 EOF:0 ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
14 0.00000112 SUCCESS
15 0.00000000 Fortecstar STB IOCTL_SERIAL_SET_HANDFLOW Serial0 Shake:1 Replace:40 XonLimit:2048 XoffLimit:512
15 0.00000335 SUCCESS
16 0.00000000 Fortecstar STB IOCTL_SERIAL_SET_QUEUE_SIZE Serial0 InSize: 10000 OutSize: 10000
16 0.00000318 SUCCESS
17 0.00000000 Fortecstar STB IOCTL_SERIAL_PURGE Serial0 Purge: TXABORT RXABORT TXCLEAR RXCLEAR
17 0.00000250 SUCCESS
18 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
18 0.00002386 SUCCESS
19 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
19 0.00000208 SUCCESS
20 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
20 0.00004681 SUCCESS
21 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
21 0.00000109 SUCCESS
22 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
22 0.00002757 SUCCESS
23 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: 3
23 0.00007976 SUCCESS
24 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
24 0.00008052 SUCCESS
25 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: L
25 0.00008138 SUCCESS
26 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
26 0.00008029 SUCCESS
27 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: f
27 0.00008063 SUCCESS
28 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: e
28 0.00008065 SUCCESS
29 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: t
29 0.00008113 SUCCESS
30 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
30 0.00008103 SUCCESS
31 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: m
31 0.00008105 SUCCESS
32 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: e
32 0.00008000 SUCCESS
33 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1:
33 0.00008140 SUCCESS
34 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: U
34 0.00008083 SUCCESS
35 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: l
35 0.00008095 SUCCESS
36 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: t
36 0.00008031 SUCCESS
37 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: r
37 0.00008137 SUCCESS
38 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: a
38 0.00008083 SUCCESS
39 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
39 0.00008064 SUCCESS
40 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: b
40 0.00008055 SUCCESS
41 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
41 0.00008167 SUCCESS
42 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: n
42 0.00008067 SUCCESS
43 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: )
43 0.00008051 SUCCESS
44 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
44 0.00008071 SUCCESS
45 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: *
45 0.00008145 SUCCESS
46 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
46 0.00008045 SUCCESS
47 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: b
47 0.00008094 SUCCESS
48 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
48 0.00008058 SUCCESS
49 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: n
49 0.00008154 SUCCESS
50 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
50 0.00008072 SUCCESS
51 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: A
51 0.00008062 SUCCESS
52 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: l
52 0.00008068 SUCCESS
53 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: l
53 0.00008140 SUCCESS
54 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1:
54 0.00008062 SUCCESS
55 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: F
55 0.00008064 SUCCESS
56 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
56 0.00008071 SUCCESS
57 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
57 0.00008155 SUCCESS
58 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
58 0.00008061 SUCCESS
59 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
59 0.00008032 SUCCESS
60 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
60 0.00008101 SUCCESS
61 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
61 0.00008138 SUCCESS
62 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
62 0.00008065 SUCCESS
63 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
63 0.00008072 SUCCESS
64 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
64 0.00008049 SUCCESS
65 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
65 0.00008142 SUCCESS
66 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
66 0.00008090 SUCCESS
67 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
67 0.00008069 SUCCESS
68 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
68 0.00008067 SUCCESS
69 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
69 0.00008146 SUCCESS
70 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
70 0.00008083 SUCCESS
71 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
71 0.00008021 SUCCESS
72 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
72 0.00008106 SUCCESS
73 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
73 0.00008139 SUCCESS
74 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
74 0.00008068 SUCCESS
75 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
75 0.00008072 SUCCESS
76 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: ~
76 0.00008056 SUCCESS
77 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
77 0.00000165 SUCCESS
78 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
78 0.00000108 SUCCESS
79 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
79 0.00000108 SUCCESS
<duplicate lines deleted>
472502 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
472502 0.00000141 SUCCESS
472503 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
472503 0.00000151 SUCCESS
472504 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472504 0.00002570 SUCCESS
472505 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: 3
472505 0.00007371 SUCCESS
472506 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472506 0.00007609 SUCCESS
472507 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: L
472507 0.00007198 SUCCESS
472508 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
472508 0.00007540 SUCCESS
472509 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: f
472509 0.00007735 SUCCESS
472510 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: e
472510 0.00007284 SUCCESS
472511 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: t
472511 0.00007680 SUCCESS
472512 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
472512 0.00007486 SUCCESS
472513 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: m
472513 0.00007674 SUCCESS
472514 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: e
472514 0.00006382 SUCCESS
472515 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1:
472515 0.00006447 SUCCESS
472516 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: U
472516 0.00007245 SUCCESS
472517 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: l
472517 0.00007227 SUCCESS
472518 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: t
472518 0.00007465 SUCCESS
472519 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: r
472519 0.00007485 SUCCESS
472520 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: a
472520 0.00006680 SUCCESS
472521 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472521 0.00006757 SUCCESS
472522 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: b
472522 0.00006556 SUCCESS
472523 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
472523 0.00007849 SUCCESS
472524 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: n
472524 0.00006465 SUCCESS
472525 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: )
472525 0.00006859 SUCCESS
472526 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472526 0.00006877 SUCCESS
472527 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: *
472527 0.00006551 SUCCESS
472528 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472528 0.00006531 SUCCESS
472529 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: b
472529 0.00006522 SUCCESS
472530 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
472530 0.00007902 SUCCESS
472531 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: n
472531 0.00006119 SUCCESS
472532 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472532 0.00006176 SUCCESS
472533 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: A
472533 0.00007270 SUCCESS
472534 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: l
472534 0.00006829 SUCCESS
472535 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: l
472535 0.00006983 SUCCESS
472536 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1:
472536 0.00006420 SUCCESS
472537 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: F
472537 0.00007519 SUCCESS
472538 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: i
472538 0.00007409 SUCCESS
472539 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472539 0.00007596 SUCCESS
472540 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472540 0.00007379 SUCCESS
472541 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472541 0.00007541 SUCCESS
472542 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472542 0.00007492 SUCCESS
472543 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472543 0.00007348 SUCCESS
472544 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472544 0.00007476 SUCCESS
472545 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472545 0.00007578 SUCCESS
472546 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472546 0.00007598 SUCCESS
472547 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472547 0.00007407 SUCCESS
472548 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472548 0.00007539 SUCCESS
472549 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472549 0.00007505 SUCCESS
472550 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472550 0.00007561 SUCCESS
472551 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472551 0.00007480 SUCCESS
472552 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472552 0.00007640 SUCCESS
472553 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472553 0.00007322 SUCCESS
472554 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472554 0.00007769 SUCCESS
472555 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472555 0.00007357 SUCCESS
472556 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472556 0.00007586 SUCCESS
472557 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: .
472557 0.00007579 SUCCESS
472558 0.00000000 Fortecstar STB IRP_MJ_WRITE Serial0 Length 1: ~
472558 0.00007386 SUCCESS
472559 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
472559 0.00000287 SUCCESS
472597 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
472597 0.00000143 SUCCESS
472598 0.00000000 Fortecstar STB IRP_MJ_READ Serial0 Length 1
472598 0.00000405 SUCCESS Length 1: .
472599 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
472599 0.00000155 SUCCESS
472600 0.00000000 Fortecstar STB IRP_MJ_READ Serial0 Length 1
472600 0.00000303 SUCCESS Length 1: .
472601 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
472601 0.00000149 SUCCESS
472602 0.00000000 Fortecstar STB IRP_MJ_READ Serial0 Length 1
472602 0.00000285 SUCCESS Length 1: .
472603 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
472603 0.00000169 SUCCESS
472604 0.00000000 Fortecstar STB IRP_MJ_READ Serial0 Length 1
472604 0.00000280 SUCCESS Length 1: .
472605 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
472605 0.00000152 SUCCESS
472606 0.00000000 Fortecstar STB IRP_MJ_READ Serial0 Length 1
472606 0.00000279 SUCCESS Length 1: |
472607 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
472607 0.00000146 SUCCESS
637641 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
637641 0.00000137 SUCCESS
637642 0.00000000 Fortecstar STB IOCTL_SERIAL_GET_COMMSTATUS Serial0
642764 0.00000000 Fortecstar STB IOCTL_SERIAL_PURGE Serial0 Purge: TXABORT RXABORT TXCLEAR RXCLEAR
642764 0.00000624 SUCCESS
642765 0.00000000 Fortecstar STB IOCTL_SERIAL_SET_WAIT_MASK Serial0 Mask:
642765 0.00000224 SUCCESS
642766 0.00000000 Fortecstar STB IRP_MJ_CLEANUP Serial0
642766 0.00000262 SUCCESS
642767 0.00000000 Fortecstar STB IRP_MJ_CLOSE Serial0
642767 0.00900396 SUCCESS
Is this a new model with the RS 232 connector not attached to the rear panel and came packaged in the carton with the brown cardboard interior rather than the white?
Boozekeg... sorry you haven't got many replies.
Since the receiver is new, and you are trying to update the factory firmware, I would suggest you contact the manufacturer or your vendor for support.
I think people haven't responded to your request because when other people have asked this question, it is usually related to how to load a bin file on their receiver to engage in signal theft. I know nothing of your intentions, nor am I making any judgements or accusations. Simply some persective as to why you may have not received many replies.
Perhaps if you clarify what you are trying to accomplish, we can be of more help!
I didn't respond quickly because it took me 4 hours to scroll down the error messages.
Try a different serial cable or wait for someone who has one of these units.
If all else fails, email Fortec for a solution, if you're trying to load a hacked BIN file it'll kill your receiver and you'll have to RMA it to Fortec who report any illegal Dish Network key flash attempts to the authorities and they'll take away your legs and two fingers of their choice.
You said you have a striaght RS232 cable.... Usually you would need a Null Modem cable to talk to another piece of equipment.
Wholeshoe
Wholeshoe
Mine works fine with a serial (non-null). I used one to organize my FTA Channel Lists on the same receiver.
Bigger dish or better LNB?
Need a little Motorized Dish Pointing help
