does anyone have this dish? I have the 6ft version and I was wondering if the signal strength of the 8ft is worth the money.
I don't have the dish but I can definitely tell you that while the added signal strength is nice, it's not as useful as the narrower beamwidth...much less adjacent satellite interference...well worth the additional 2 ft. IMO...
Thanks much. I'm getting another 8 ft CM SMC prepared to add, and I'm going to move the 10 ft CM to a new pole, possibly to split domestic C and KU to two seperate dishes.Hey ACRadio,
I checked out your Dish Farm from the link in your signiture and I'm impressed especially with your 8' Channel Masters. I just happened to have one that I got free and I'm really happy with it.
Nice Farm Bro!!!![]()
Actually it's 9 feet. My 8 footers are 2.2 degrees and the 10 is 1.7 degrees...I can see just a bit of the adjacent satellite on the 8 footer with the analyzer...I can even see a tick on the 10 footer but it is about to be moved and isn't peaked...8' feet in diameter is the recommended minimum size for 2 degree interfence rejection at C-band frequencies. 6' dishes are nice and work ok but 8-10 for c-band is best (or larger).
I would like to have a 16' dish.
Limited time offer
