Formatting test | SatelliteGuys.US
Formatting test
Not open for further replies.
Hall
18,409
3,199
Germantown OH
Testing something here.... I had posted a reply and am 99% positive that the text went all the way to the right-edge of the 'window' and then wrapped. I edited the post and noticed it looks like I hit 'enter' and make the lines shorter. Just testing... This will be random text to fill the box some.
(Copy and pasted text)
As I mentioned above, you can run a "stock" ROM with the exception that it has rooted access. Otherwise, it's just as Verizon/HTC supplies, right down to the "bloatware" that they normally include. Being rooted, you'll have alternative tethering options available to you then.
Here's one example: [GB][2.11.605.3]Debloat, Stock, Rooted (I would expect a new version based on 2.11.605.5 very soon, but for your reference, this will suffice)
Ughhh, why all the empty space on the right ? Blows my theory that editing the post did it...
I'm using Google Chrome on MAC OS X, if that matters. See the screenshots to see what I'm seeing
Arghh! It did it on the above post I just made too.... Hehe, you guys probably don't see it though !! It wraps after "see what I'm" and "seeing" is on a new line.
If you're seeing a lot of white space on the right, it is probably VB leaving room for an ad.
You may be able to cure this with a paid subscription. ;)
A comment and a question on the Satguys app
my firefox doesn't see the security box on the raffle
