The format button will work on HD channels but will not on SD channels such as Espn news and ESPU; your stuck with a small screen in the center with a black background. The screen stays on normal on the hopper w/sling. On my Joey it stays on Zoom.
Have you tried the format button on your TV's remote?
As good as DIRT is they don't write the software the only answer they can give you is a "DISH SOON" when it happens it will happen and not before then.This is a known issue with the Hopper with Sling and will be fixed with a future software update.
Next software update
Lots of cool stuff in this update, including the HDMI-CEC (automatically turns TV on and to the proper input), the subscription VOD on a channel adjacent to the subscription channel, and yes, fixing that SD format issue.
I'm sure it would be no different than them pressing the On Demand button. If you have a limit don't use VOD or monitor it closely enough to not go over.
Limited time offer
