Forced program guide download | SatelliteGuys.US
mteller
11
Is there anyway to force an 811 receiver to download the program guide? I scroll right but it just seems to lock up.
You can do a soft reboot by holding the power button in on the front of the 811 for several seconds. Once it shuts off it will acquire channels and refresh the EPG.
Thanks, Erik! :up
However, Erik's problem was that his DPP-Twin (on a D1000) was locking up. Pulled the feed cables on both receivers (drop power to the LNB) to force the LNB to reset.
First time I ran into that with a DPP-Twin, but I'm not surprised - I've seen it happen with most other DishPro switches (external or internal to the LNB).
New Hdtv Dish Channels That Don't Work??
Dish Support - Would You Be Happy?
