Font Double Size | SatelliteGuys.US
Font Double Size
Not open for further replies.
Bobby
Publican
72,689
29,793
Rohnert Park, CA
I've done this before and fixed it but I can't remember how. I did a control something or other while in one of the forums and now my entire Satellite Guys website is double in font size. When I go to any other website all is well, it's just Sat Guys. I know it is a simple fix but I can't fathom the it. Any help please...
I hope you get a reply, I would like to find out how to enlarge the font a few points !
Are you talking about how in Windows, you can do ctrl+ and ctrl- (hold down control key while pressing the plus or the minus key) to increase or decrease/zoom in or out?
I just fixed it. I simply pressed "control -" .... If you press "control +' it will go up in size but it only seems to double.
Thanks Navy, I was typing as you chimed in. :)
Lots of Database errors
Roge Ad.
