Fitting a regular c/ku fedhorn on a 1.5 Meter offset | SatelliteGuys.US
Cband55
202
Has anyone done it do you get strong c band channels, how did you fit it
thanks
http://www.skyvision.com/store/media/3503007.jpg
http://www.mayortec.com.mx/images/1.50 antena.jpg
Since it's an offset dish, you might consider using a conical scalar.
That should help C-band.
No clue how Ku would work.
Where did you get a 1.5 meter dish in North America?
They are not very popular.
Any special reason to hook up these parts?
Not exactly a package I'd go out and buy and try to tie together.
edit:
Where are you located, and what satellites/transponders are you trying to receive?
later edit:
You might take a look at this other thread concerning offset dishes, for additional comments.
they are surplus parts I just happen to have, I Would like to get both c and ku band, I g9t the 1.5 to get Pas 3 at 43 but a wall is blocking the sight
Great News! Local Cable rates went up!
anyone getting US Courts on 93W?
