Firmware update broke Coolsat 4000 Pro out loop? | SatelliteGuys.US
mchomicz
SatelliteGuys Guru
After I upgraded to this latest firmware version ( http://www.satelliteguys.us/showthread.php?t=80565 ) it would seem that the LNB loop no longer works the way it used. That is - loop no longer works when the receiver is in stand by mode. It has to be turn on for the loop to be active. Otherwise my "slaved" receivers don't get any signal. Before the upgrade - as long as the receiver was plugged into a power source - the loop worked (in fact - I think it would STOP working when the receiver was woken up from stand by - exact opposite of current behavior).
Is this a known bug in the latest firmware version? Or was previous behavior a bug and this is how most FTA do the loop? (I can see why this would be useful in some cases; though ideally this would be configurable) Anybody else noticed this problem?
Thanks,
Michael
Question about Viewsat VS2000
Dish is coming down...
