Firefox bookmarks problem | SatelliteGuys.US
navychop
62,156
30,338
Northern VA
It used to be that when I would bookmark a page in FF, I would be given the list of my bookmark folders. I could then pick which one I wanted the bookmark to be stored in.
Now, for the past few months, when I bookmark a page it goes to the bottom of the list. I then have to move it to the correct folder/subfolder. I've fiddled with the destination but can't get the one step bookmarking like I used to.
May be connected to when I started anew and imported saved bookmarks in.
Anyone understand what is happening or how to fix it?
is it still doing it? maybe save your favs and then uninstall & reinstall FF
Its been this way for months. I'm dreading doing the uninstall & reinstall, time wise. I might do this, and go w/4 beta. Exporting and saving the bookmarks seem to behave differently- I'll have to look into this.
maybe you had an add on called Xmarks and forgot to put it back in? It gives me all the options your talking about.
I used to have Xmarks. They've discontinued it, I believe.
navy- I have the same thing here. Been that way for so long I forgot about the options. I just bookmark and then slide them into the right location.
Internet based radio and tv gadget
This is WHY Apple Products are so dang good!
