Finally!!! | SatelliteGuys.US
Finally!!!
ACD
SatelliteGuys Guru
123
After a month messing with the dish and positioning and puulin what little hair I have left, I took the dish down. I then pulled out a peice of 1 1/2" Heavy wall conduit that used to be the downpipe for our electrical service(I forgot I had it) Drilled two holes in it, mounted it plumb to my post and then mounted the dish, it is at least 10' in the air now. I rewired it have the Diseqc switch in place, and the DSS LNB connected. Pointed to true south, pulled in T8 and noticed the quality is still poor, ok it wasnt height related. Then I started fiddlin with the elevation, latitude, and found again, nothing. THen for the heck of it,I started flexing the dish. Bingo! The dish was not lining up with the LNB. I wound up sticking a washer under the top bolt that connects the dish bracket with the LB arm. I NOW have 11720 channels, althought the quality isnt great, it is enough so the channels are viewable. My QPH-031 came in, but was delivered to the office so I wont be getting that home until Tuesday evening. WIth any luck this should make a huge difference. I now have CBS and ABC. (Doing Happy dance) :D :p
Satellite Newbie
Need Advice
