Feedhorn mod for FTA | SatelliteGuys.US
njcunha
2
I have an excellent and expensive feedhorn ( ADL rp1 CP400 cKU ) and need advices on how to replace its LNB for a new LNB model to get all Vertical and Horizontal channels without use skew control. My Viewsat Xtreme doesn't control the polar rotor
I need a lnbf recommendation that changes polarity using voltage or frequency shift sent by Viewsat receiver( and fits in the feedhorn flange).
I think you will have to change the feedhorn to this:
ADL-RP3-2-2B, found near the bottom of this page:
http://www.sepatriot.com/feeds-ADL_C_Ku.htm
of course this will take some extra lnb's.
On the other hand, you could change to an lnbf, since they now make them combined as a C/ku lnbf, as found 3rd down on this page:
http://www.satelliteav.com/shop/category/LNB
I'm sure the lnb's you already have are probably better than any lnbf you might get. These are just some idea's, hope it will help you figure out what you want. Good Luck!
Al
BBC broadcasts over ku band in North America?
Help for a new comer
