Feature Request: Instant favorite add | SatelliteGuys.US
crosspaws
60
Grand Haven MI
Uselessness I missed it how about mapping a button to place a channel in to favorite while on the channel. Some times it would be nice after doing a blind scan you spot a program that you want to dump to faviorte, you press it and you get add to favorite. Just a thought. This Is the best box I have used. My fortecStar is still my favorite for setting up a dish, but no HD. It has been great to get my 741 lnb working like I wanted. I know some don't like/bad luck with c/ku lnb but it has worked well in my 10' uni-mesh dish, geosat pro and VonWess motor. The geosat is the first box that I have gotten the C and Ku TP to come in like they should. !! It is a amazing peace of work ths GeoSatPro!!!:crowdbounce:
May be able to add this feature after pressing the LIST/OK key, but probably not a high priority list as it is so easy to Set favorites in the Channel Manger menu.
EPG data 97W G19
Need help with finding CCTV-4 on microHD
