GEOSATpro - FAQ: MicroHD: How to Save Firmware (.abs), Default Database (.ddf) or User Database (.udf) file to U | SatelliteGuys.US
GEOSATpro FAQ: MicroHD: How to Save Firmware (.abs), Default Database (.ddf) or User Database (.udf) file to U
SatelliteAV
6,486
186
Roseville, CA
02/10/2013
GEOSATpro microHD
How to Save Firmware (.abs), Default Database (.ddf) or User Database (.udf) file to USB
Save File to USB Drive:
  • Insert the USB drive into the microHD rear panel USB port.
  • Press Menu key then press the Down Navigation Arrow key to select and highlight the Tools Menu icon.
  • Press the List/OK key to display the Tools Menu screen.
  • Press the Up or Down Navigation Arrow key to Select Save to USB.
  • Press List/OK key to display Save to USB screen.
  • With the Save Mode line highlighted, Press the Right Navigation Arrow key to select the type of file that you wish to save to the USB. Firmware (Allcode.abs), Default Database (defaultdb.ddf) or User Database (userdb.udf)
  • Press the Down Navigation Arrow key to highlight Start.
  • Press the List/OK key to save the file to the inserted USB drive.
  • "File Successfully Saved" will appear when the save is complete.
  • You may continue saving other file types or exit the menus.
To Safely Remove the USB Drive:
  • Press the Exit Key to return to the Tools Menu screen.
  • Highlight Disconnect External USB Device and Press the List/OK key.
  • "Disconnect External USB Device" will be displayed. Highlight Yes and Press the List/OK key.
  • The USB device may now be safely removed from the microHD.
GEOSATpro Factory reset ?
GEOSATpro Feature Request: Auto-Tune
