Factory Fresh Reset | SatelliteGuys.US
Factory Fresh Reset
noxid8
16
US
Anyone know how to reset the 922 to where it wipes everything clean and makes as if from the factory? The menu option just resets settings but doesn't completely wipe it. Like to try this before having to send it back to Dish for a replacement.
Thanks.
I would imagine the key sequence is different for the 922. You will probably want to call Tech Support.
There is a thread on this board somewhere that has a sequence for the old 522. It worked on the later models as well, but I could not find it with a quick search. I would save some time and make the call.
Google TV Premiering w/Dish
Bye bye and Thanks, Dish!
