F/D Ratio similar .3575 BSC621 10' Bud ??? | SatelliteGuys.US
phpinfo
294
USA
The BSC621-2 doesn't have any F/D ratio markings on it, but my ratio is 0.357575.
Does anyone have a similar ratio and if so can you measure from your scalar ring to the tip of the feedhorn and tell me how much it is, in inches? 1/2", 3/4" ?????
10' Winegard Bud
22" depth
F/L = 40.9 - ~1/4" on BSC621-2 ??
those numbers sound close to my 10 ft dish
mine is set 1/2 inch below the scaler and could be closer to 5/8 of an inch below.
your F/L should be about an 1/8 inside the feedhorn
Good stuff. Thank you!!
Also found this chart:
Inches -- f/D
.12 ------ .42
.32 ------ .40
.52 ------ .38
.72 ------ .36
.92 ------ .34
1.12 ---- .32
From The DMS  BSC621
FEC Ratio and Dish size
SBS-6 Move
