None that I've ever used which makes me too curious as to what is giving you that message.I changed the hdd enclosure, & when I turned it on, & saw a message to format the hdd, of course I reversed what I did. Does that mean if the enclosure needs to replaced, all recordings are lost ?
What was the HDD in before you changed it to the new enclosure?I changed the hdd enclosure, & when I turned it on, & saw a message to format the hdd, of course I reversed what I did. Does that mean if the enclosure needs to replaced, all recordings are lost ?
You should go back to the original enclosure if you can. Once there and everything is working again, there are some options.I changed the hdd enclosure, & when I turned it on, & saw a message to format the hdd, of course I reversed what I did. Does that mean if the enclosure needs to replaced, all recordings are lost ?
OK my friend. First of all I'm going to get a mod to move this to the DIsh forum so we can get all the experts over there working on it. Yes, we've seen such problems before over there. Which Dish receiver do you have?I change because I liked the other better for my computer, it had no problem, & did put it back, & it's working as before. Now that I think of it, I had a heck of a time getting my computer recognizing a new ssd in the problem case. After screwing around in disk management, it worked. So...the reformat thing usually doesn't happen ?
He said the old enclosure worked when he went back to it. The new enclosure also had issues when he tried to get his computer to recognize an SSD in that same enclosure. He is working fine now that he went back to the original enclosure. It ain't broke why fix it...Assuming the old enclosure is Ok.
The hopper probably just noticed a different configuration for the EHD. Plug it in, do not accept the reformat message and call Dish Support and have them resend an authorization ping to your Hopper. That will cause the hopper to scan all the attached devices.
Limited time offer
