External DVR disappears after last update | SatelliteGuys.US
Evil Z06
26
6
South Florida
Since the last update(U313) I have this issue....When I hit the DVR button it shows all my recordings but it does not show my external DVR....if I unplug it and plug it back in and it does show it but the problem is when I turn the Hopper off and then on again it disappears again... Any clues...thanks
Dumb question but which button on the H3? Hold in the power button or hit the red reset? Thanks
I think you are exactly right. Hold or press, both should work. Not sure how long to hold so red will be quicker.
Not sure calling an EHD a DVR is exactly right....... :) just sayin.
Reactions: xfoneguy
UPDATE:
It's happening again.The last two mornings when I turned on my TV and hit the DVR button....the external EHD was missing and I had to unplug the EHD and plug it back in to make it work.Any suggestions? Thanks
UPDATE:
If you got a power button on your EHD use it, I don't leave my EHD on I leave mine off until I need it. It also could be your EHD is starting to go bad, I tested mine I left it on and turned off the hopper3 when I turned it on my EHD was still on in DVR. What EHD do you have and how large?
Try unplugging both the receiver and the external hard drive and then plug both back in , in that order and it should see the ex. hard drive again. I had to do that very thing yesterday to get it to see my external hard drive. A power cord reboot usually clears out just about all issues with the receiver.
Reactions: charlesrshell
Before the update there was never a problem and I left it on all the time.I have a Seagate 500 GB...Thanks
Thanks I will try that after work today and I will let you know...Thanks....Like I said before the update I never had a problem
Reactions: MikeD-C05
MikeD probably has the better idea but if that doesn't work get ahold of dirt and have them hit your receiver and do what MikeD said....
I just did it and of course it works right now but the real test will be tomorrow when I turn it on..Thanks again everyone and if this doesn't work I will contact a Dirt member.
Dish 1000.4 vs 1000.2 Setup
Manual timer creation on Hopper 3
