Extension Cable for Winegard Carryout G3 | SatelliteGuys.US
mitch5252
28
8
I have the older Winegard Carryout that has 2 cables coming off it.
The new Carryouts have power through coax.
Occasionally, I need longer than Winegard's included 25' cable. Can "regular" coax be used in these new units as extension cables, or must I buy some different type of cable and the corresponding connector?
Thanks for your help.
You just need a longer cable ?
Yes, you can use any RG6 cable and make up a longer length.
Don't forget the Barrel to put them together with.
Directv RGB or Ybcr?
New Equipment
